Vibration cont.
Old Oct 27, 2003 | 10:58 PM
Movnviolation's Avatar
Movnviolation
Default Vibration cont.
I guess that I wasn't totally clear in my earlier post. The vibration is moving or not. I can feel it sitting in my driveway. It is not wheels or tires. I'm thinking clutch area.
Thanks again
Russ :steering:
Old Oct 28, 2003 | 06:52 AM
Dark-Knight's Avatar
Dark-Knight
Default Re: Vibration cont. (Movnviolation)
Russ, another inexpesnsive check, before you start tearing into things, is your exhaust system it can cause lots of vibrations and reasonance. Get your car on a lift and go over the exhaust sys inch by inch. Make sure it is not touching any part of the body and that all the rubber vibration dampers are seated properly. Closley check your reasonator, it's hard to see behind it.
Good luck! :thumbs:
