trouble codes
Old Oct 28, 2003 | 08:02 PM
1990CORVETTE's Avatar
1990CORVETTE
Default trouble codes
Where can I find trouble codes
12
13
32 EGR Valve "Right"
Old Oct 28, 2003 | 08:56 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: trouble codes (1990CORVETTE)
12 - std startup codes tells you system is ready and will flash 3 times - then error codes will follow each flashing 3 times, and ending with 12 flashing 3 times
so you have
12 x 3 - system ready
13 = Oxygen Sensor Unit (Diag: Check wiring and connection - Bad Sensor)
32 = Exhaust gas Recirculation Circuit (Diag: most common cause of this code is a bad or intermittent EGR switch which is located on the EGR pipe between the exhaust manifold and the intake maniforl. Replace this switch first when you get this code. Next check electrical connections at the EGR valve solenoid and then the ECM - Check all vacuum lines for leaks esp. around the EGR valve. Possible ECM failure.
