I have 2 12" in the back of my vette. Anyone else have 2 12"? I'm tryin to find a premad, or perhaps and idea to construct a better box so I can store the top in the back to. Any advice?
i also have 2 12s and i dont think that you can find a box or make one that will give you the full effect of the subs. i got the smallest box that i could and the top still could not fit, so i tryed to make a box my self, well it looked good but sounded like poop, so if you care how your subs sound get a good box and dont worry about the top. but if you want to put the top in that bad just get a very small box and your set
but you can always fit the top in. this is what i do most of the time when i take my top off i can slide it in the holders in the back but it wont lock in so what i do i just rest it on top of the box. i mean yea its not the right way but it stays in place and does not go any were
3- 8inch from JBL, and the targa top may fit?As far as 12inch and the top my gess you'll need to get rid of the spare tire use the "well" and put only 1 sub in I think a 12,15,18 would fit and the top.
Well I guess the Spare is mounted underneath,so some cuting and encloseing may be need. Sorry. :crazy:
I have 2 Orions and the box I had made has a big flat top because I wanted to be able to slide the cargo cover over it. The subs are mounted on an angle and backwards to save airspace and height.
I mounted the amps on the front of it and when my beotch wants to go topless, it just sits on top of the box and stays put. It kinda sits flat between the seats and the back cover.
