I have talked with Two Dearlers in the Indy area and they couldn't help. I am missing a Plastic panel that appears to protect the Antenna from road dirt ( and snow if you drive it in the Winter). On the passenger side there is a similar panel but not on the drivers side. I can't see a part no on the that is on the passenger side and it has push pins that secure it to the Chassis.
Any Ideas besides selling the Car. [IMG][/IMG] [IMG][/IMG]
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Re: Chassis Panel under Antenna (92nred)
Your post got me to wondering if ours was missing too (94 LT1 Coupe) since the passenger side has one, but the our driver's side doesn't.
However, after closer examination, there are no holes in the frame which would be required for the two push-pins on the driver's side, so it isn't 'missing' on ours (or at least never installed at the factory).
Does yours have the two holes in the frame where the push-pins would go on the driver's side?
