sun roof problem
Old Nov 6, 2003 | 01:34 AM
vegasvetteman's Avatar
vegasvetteman
Navigator
Default sun roof problem
I bought an aftermarket sunroof for my 84 about 4 yrs. ago and about a year ago the roof panel became loose from the frame.I've been told it's not a simple silicone fix,but a two stage glue job that requires taking it off the frame and cleaning it with a solvent first.Is this a job I could do myself or should I take it to a professional.
Old Nov 6, 2003 | 06:56 AM
Dark-Knight's Avatar
Dark-Knight
Default Re: sun roof problem (vegasvetteman)
If you had it installed you may consider having someone else do the repair.
:seeya
Old Nov 11, 2003 | 01:36 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
I would think that a PRO Shop would do the repair better. Just my thoughts.
Good Luck
tony
Old Nov 11, 2003 | 01:49 PM
JCAIRE2's Avatar
JCAIRE2
You'll spend just as much for the glue and applicator as you would to take it to a shop. I had the same problem you're having. I was quoted $75 to repair it. For that quote I had to seperate the top from the frame and clean up the mating surfaces with a dremel tool. Once that was done, I took it to the glass shop and they glued it back together. I took them the top in the morning and had it back on the car that afternoon. :cheers:
To sun roof problem
