Help for Corvette Bretheren....
Old Nov 16, 2003 | 09:15 PM
RED-85-Z51's Avatar
RED-85-Z51
Default Help for Corvette Bretheren....
Hey, I got a friend at school, with a 94 comp yellow coupe. It is low miles, around 50K and he is having tranny issues. He says that when the tranny warms up, it seems sluggish to shift, and the accellerator has to be floored to get it to downshift at all while moving. and even then, its downshifts strangley. He says when its at temp, it almost refuses to upshift, and the engine revs really high before it shifts. What could be his problem?
Old Nov 17, 2003 | 06:03 AM
MyBlueC5's Avatar
MyBlueC5
Corvette ***** OG
St. Jude Donor '05
CI VI Veteran
Default Re: Help for Corvette Bretheren.... (RED-85-Z51)
Sounds like it may be time for a rebuild. Usually if it doesn't seem to shift into the next gear and free revs like he has a converter, then it may have lost that band. eg. shifting from 3rd to 4th and it revs almost a 1000 rpm before it goes into 4th usually means that 3-4 band is gone.
I'd take it to a competant trans tech and have him drive it. He'll be able to tell you with a test drive (generally)
Mark
Old Nov 17, 2003 | 05:56 PM
HapAFcop's Avatar
HapAFcop
Default Re: Help for Corvette Bretheren.... (C4 Newbie)
:iagree: At best, low fluid. Worst case scenario would be a rebuild. Right now it just sounds like a band; he should get it checked out quickly before he damages any of the "hard parts."
Old Nov 17, 2003 | 07:46 PM
RED-85-Z51's Avatar
RED-85-Z51
Default Re: Help for Corvette Bretheren.... (HapAFcop)
I talked to him today, he said it happened fairly suddenly, but that the fluid is fine. Did I also mention that he does alot of hard accelerating? and a bunch of smoky burnouts?
Old Nov 17, 2003 | 10:23 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Have him check the vacuum line to the trans. It must be hooked up and be in good shape...no leaks.
I hope that's all it is....
Larry
code5coupe
:seeya
To Help for Corvette Bretheren....
