Torque converter
Old Nov 17, 2003 | 11:54 PM
redaz94's Avatar
redaz94
Default Torque converter
I have a leak in my torque converter seal, so I am having my rear main and TC seals replaced together (same labor). Also, once in a blue moon my car will lunge when putting into reverse or drive (happened twice in 11 months. Can this be a torqu converter issue? Should I also have that replaced or am I jumping the gun. I have a 94 LT1 auto with 87000 miles. Thanks, Ron
Old Nov 18, 2003 | 05:16 PM
Q1KSLVR's Avatar
Q1KSLVR
Default Re: Torque converter (redaz94)
I would just do the seals and not worry about the lunging.
It may be just you putting it in gear with a high idle.
Hope this helps! :thumbs:
Old Nov 18, 2003 | 11:53 PM
ZR-71's Avatar
ZR-71
St. Jude Donor '15
Quote
________________________________________ ________________________
:iagree:
The computer controls the idle and any number of reasons could cause a high idle. If you're concerned enough, always look at your RPM's whe you shift into gear. RPM's should be less than 1000, if higher you could get a lurch.
:seeya
To Torque converter
