Fuel pump pressure
Old Nov 19, 2003 | 02:23 AM
BubbaJJ's Avatar
BubbaJJ
Default Fuel pump pressure
what kind of pressure should the fuel pump put out on an 86? I took the pump out and it seems to be putting out next to nothing.
Old Nov 19, 2003 | 12:06 PM
Southern Comfort's Avatar
Southern Comfort
Default Re: Fuel pump pressure (BubbaJJ)
40-45 at the rail at Idle. Thats what my new ACDelco puts out.
Old Nov 19, 2003 | 03:28 PM
BubbaJJ's Avatar
BubbaJJ
Default Re: Fuel pump pressure (Southern Comfort)
this means my pump is dead. Thanks
Old Nov 19, 2003 | 10:50 PM
grapeknutz's Avatar
grapeknutz
St. Jude Donor '06
You may want to check the fuel filter it may be plugged up!
Old Nov 20, 2003 | 01:39 AM
BubbaJJ's Avatar
BubbaJJ
Default Re: Fuel pump pressure (grapeknutz)
I pulled it out of the tank and benched it. I also put it back in and pulled the feed line and it was making very little presure at the tank. Is the fuel filter in the tank with the pump? I didnt see anything that looked like that. If it's making five pounds I'd be surprised. I will do the filter as soon as I can find it. Did I mention that I'm a C4 newb?
:steering:
Old Nov 20, 2003 | 01:45 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
If your 86 is close to my 87, its behind the ps wheel well. make sure you releave the pressure first...
To Fuel pump pressure
