Does your steering column wiggle also?
Old Nov 19, 2003 | 01:25 PM
milehighvette's Avatar
milehighvette
Default Does your steering column wiggle also?
I have tried to rebuild my old column and now I just replaced it with a used column out of a wrecked vette with only 30K miles on it and this column has some tilt steering wheel wiggle in it also. Is this just something I am gonna have to live with? How many others out there have the same issue?
Old Nov 19, 2003 | 01:44 PM
MPforUSMC's Avatar
MPforUSMC
Default Re: Does your steering column wiggle also? (milehighvette)
My '92 has about a half to an inch play to it. I was told to rebuild my column too...but heard it was expensive. SO ill live with the jigg for a while.
Old Nov 19, 2003 | 03:01 PM
cicch95's Avatar
cicch95
Finalist 2020 C4 of the Year - Unmodified
Default Re: Does your steering column wiggle also? (MPforUSMC)
I have heard that this happens from using the steering wheel to pull yourself in and out of the car. It weakens the screws that hold the column in.
-Rick
Old Nov 19, 2003 | 03:06 PM
sraft's Avatar
sraft
How far along did you get in trying to rebuild the column? Was it too involved for the shade-tree mechanic to do in their driveway? Like (almost) everyone else, I have the same wiggle and would like to fix it. If you have a list of the required parts, I would really appreciate if you could post them.
Old Nov 19, 2003 | 03:20 PM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
Mine is in great shape. I have hear the rebuild can be a bear?
Old Nov 19, 2003 | 03:28 PM
robertpel9's Avatar
robertpel9
Default Re: Does your steering column wiggle also? (LT-4 CE)
mine has a wee little jiggle from the owner before me using it to get in and out of the car (he wa sin his late 60's or so). I live with it in fact i dont even notice it. DO NOT use you wheel to aid in ingress and egress
Old Nov 19, 2003 | 04:52 PM
4-ACES's Avatar
4-ACES
From: Northern KY.... Just 3 hours to Las Vegas in a 767
Default Re: Does your steering column wiggle also? (robertpel9)
No, mine doesn't wiggle but if you rub on it in just the right spot the
seats get wet...... :lol:
Old Nov 19, 2003 | 06:05 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Default Re: Does your steering column wiggle also? (4-ACES)
C4play? :bb
Old Nov 19, 2003 | 07:30 PM
Rich & Lisa_84's Avatar
Rich & Lisa_84
From: I live at www.domesticlugnuts.com I sleep in PA
Default Re: Does your steering column wiggle also? (corvetteronw)
:rofl: :lolg: :rofl: :lolg: :rofl: :lolg: :rofl: :reddevil :iagree:
Old Nov 19, 2003 | 11:25 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
:D :D Nice one :lol: :lol:
Old Nov 19, 2003 | 11:52 PM
MyBlueC5's Avatar
MyBlueC5
Corvette ***** OG
St. Jude Donor '05
CI VI Veteran
Only when her butt hits it. :rofl:
Seriously, my steering column wiggles ever so slightly. I think they probably all do to a certain extent. Unless it vibrates excessively, I wouldn't worry about it. Do you have someone else's you can compare it to?
Mark
Old Nov 20, 2003 | 12:49 AM
MrRenoman's Avatar
MrRenoman
I have an 85 and it used to do this. I finally removed the steering wheel and all the guts at the top of the column. I even removed the tilt spring and assembly to get to the bolts that hold the part of the column that was loose. I could only get to 2 of the 3 bolts that held it together. These bolts are torx head bolts. You need a torx socket with the torx female hole that fits on the bolt head. Once the 2 screws were tightened, I put it back together and now it has no slop. It's a little involved, if you haven't played with the turn signal wiring, or messed with the steering wheel removal and tilt mechanism it can be a little intimidating. The book wasn't a whole lot of help either.
Old Nov 20, 2003 | 10:31 AM
Bilyk's Avatar
Bilyk
mine sure does! :hurray:
Old Nov 20, 2003 | 10:38 AM
C-4 Cross Fire's Avatar
C-4 Cross Fire
Default Re: Does your steering column wiggle also? (Bilyk)
Believe it or not, lack of tred on the front tires will cause this every time! How's your tred?
To Does your steering column wiggle also?
