Tuner Removal
Old Dec 8, 2003 | 08:53 AM
Goodfella's Avatar
Goodfella
Default Tuner Removal
Ok experts. I am back, and suprise, with another question. I am going through the stereo nightmare, and it has been determined that I need to replace my tuner. After contacting Dr Don's, they suggest that it gets replaced, which will be a lot cheaper than replacing the entire stereo. My question is, how do I get to it? :confused:
Old Dec 8, 2003 | 05:32 PM
c4cruiser's Avatar
c4cruiser
Default Re: Tuner Removal (Goodfella)
There's a Tech Tip about replacing the bulbs inside the tuner and it has a description of how to get at the head unit. Go up to "TOOLS", then to "TECH TIPS", and select "C4". It's down about halfway.
https://www.corvetteforum.com/techti...=249&TopicID=2
Old Dec 8, 2003 | 07:38 PM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
Not sure about the location on a 92. In my coupe the tuner box is located under the glove box. Also referred to as the CDM. I have removed mine twice...two times more than I wanted to. I have to take out the seat to get my fat behind in there. Then alot of cussing and moaning. I don't want anyone else in the garage when I do that job! :mad
[Modified by brdd, 6:40 PM 12/8/2003]
Old Dec 9, 2003 | 08:34 AM
Goodfella's Avatar
Goodfella
Default Re: Tuner Removal (brdd)
Thanks for the tips. :hurray:
Old Dec 11, 2003 | 02:03 AM
Phil stock 91's Avatar
Phil stock 91
the recever is under the glove box
Old Dec 11, 2003 | 08:16 AM
Goodfella's Avatar
Goodfella
Default Re: Tuner Removal (Phil stock 91)
Is there a easy way to get to it? :confused:
Old Dec 11, 2003 | 10:21 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Been said before: :lol: Remove the seat... First... that gives you the most room... unless your 98lbs...
Old Dec 11, 2003 | 11:53 AM
Phil stock 91
Default Re: Tuner Removal (vinnies87)
remove the trim on the end of the dash around the fuse panel then you can see a lot better when you look in from the end helped a lot on my 91 dont know if they are the same
To Tuner Removal
