90-96 dash cluster
Old Dec 10, 2003 | 03:11 PM
adelii's Avatar
adelii
Default 90-96 dash cluster
Does anyone fix these clusters or do i have to buy a rebuilt one or used one?
Old Dec 10, 2003 | 06:53 PM
xlr8nflorida's Avatar
xlr8nflorida
Default Re: 90-96 dash cluster (adelii)
Yes you can fix them.
AER
Advanced Electronics
Remanufacturing
Dept CF
1841 W. Commonwealth Avenue
Fullerton, California 92833
800.321.6970
Be careful removing the unit- the wiring loom attachment is in the back of the instrument panel. Be careful of the connectors and dont pry at the panel to remove one, as it will probably break. The repair will probably be under $500.00.
Or you could try ARTS corvettes in Fort Lauderdale and see if he has a used one cheaper :)
Old Dec 10, 2003 | 10:32 PM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
Are you sure the cluster is bad? You can pick one up off ebay for decent price. I would suggest findind a 92 or 93, the 94-96 will have white lettering, but they will work. Here's a 92 http://cgi.ebay.com/ebaymotors/ws/eB...category=33675 From -=Jeff=- FYI to those swapping clusters
90-91 Are interchangeable with each other (L98 and ZR1)
92-96 Are interchangeable with each other (LT1, LT4, and ZR1)
The 92-96 will not work in the 90-91 or vice versa UNLESS you swap the LCD Panel.
The LCD panel for 90-91 is different for 92-96.
I have a 96 LT4 cluster in my 91 Dash but I am using my 91 LCD Panel in the cluster
:steering:
Old Dec 11, 2003 | 12:22 AM
GhosTRydeR_92's Avatar
GhosTRydeR_92
Default Re: 90-96 dash cluster (Ramrod92)
does the cluster keep the mileage memorized or does the ecm/pcm do that i got to change my cluster out to and i was wondering if i got one out of a higher mileage vette would it show in my car
Old Dec 11, 2003 | 01:35 AM
JOliver's Avatar
JOliver
Default Re: 90-96 dash cluster (corvetteman_340rwhp)
The ECM/PCM keeps the mileage recorded.You can change clusters with no problems there.
Jason
VetteInstruments@aol.com
Old Dec 11, 2003 | 02:57 AM
GhosTRydeR_92
Default Re: 90-96 dash cluster (JOliver)
thanks jason god i love being apart of such a beatiful thing :auto:
Old Dec 11, 2003 | 06:12 AM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
Jason
Good info. I learned something today. :cheers:
Old Dec 11, 2003 | 01:50 PM
adelii's Avatar
adelii
Default Re: 90-96 dash cluster (joecaver)
how cheap is it to fix the clusters anyone know. how about the chevy dealers
Old Dec 11, 2003 | 03:27 PM
-=Jeff=-'s Avatar
-=Jeff=-
:steering:
:thumbs: Thanks Ramrod92...
Old Dec 11, 2003 | 07:41 PM
Goody's Avatar
Goody
Jason
:nono: :nono: it doesn't. It is stored in the CCM up inside the dash. The ECM is just the Engine Control Module. PCM = Powertrain Control Module.
To 90-96 dash cluster
