Anyone know how to manually move a power seat forward / back? Everything on my seat works except the forward and back movement and I would be more comfortable with it forward about another inch.
I recently swapped mine and you have to remount the seat on the drive rack. Easy to do. remove both seat bottoms (held in by a spring clip under the front edge) and notice the bolt hole patterns. Only takes a few minutes and will let you clean under the seat while you're at it!! I found over a dollar in change and the 6 speed insert to the shifter!! Also a good time to shampoo the carpet while all that hardware is out!!
Passenger seat is manual; thanks, but that won't help. I've had both seats out and have examined all the power hardware under the driver's seat, but can't figure out how to manually move it forward.
I had a motor failure in a 76 Buick Pace Car seat and disconnected the motor connection to the gears and was able to adjust the seat by manually turning the gears. It was a long time ago but I think I was able to turn the mechanism with my fingers with the seat still in place though a bit awkward. Once you get the seat apart as per Bob Taylor1 it should be apparent if you can do similar if you're not inclined to replace the malfunctioning unit.
