Interior Lighting
Old Dec 23, 2003 | 03:27 PM
CaliforniaVette's Avatar
CaliforniaVette
Default Interior Lighting
On my 96, I have a drivers Powerseat, but the display does not light. I thought it was supose to? how do i get to the bulb or is there a fuse?
Old Dec 23, 2003 | 06:26 PM
ductape's Avatar
ductape
Cruise-In V Veteran
Default Re: Interior Lighting (CaliforniaVette)
:skep: What display? I've got an '85, so there's a difference.
Old Dec 23, 2003 | 10:53 PM
CaliforniaVette
Default Re: Interior Lighting (ductape)
Its on the Console, where the control for the powerseat is, the writing and Outline does not light up
Old Dec 23, 2003 | 10:59 PM
GhosTRydeR_92's Avatar
GhosTRydeR_92
bulb is blown u have to remove the console plate and remove the seat controler and on the back is where u will find the bulb remove and replace o yeah if u have automatic be sure u get the shift indicator put back on the pin properly or the needle that indicate the gear your in wont work thanks
dax
Old Dec 23, 2003 | 11:22 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I don't believe there is any lighting for the power seat control, my '95 or '93 doesn't have any lighting, just the light in the mirror which shines down.
Old Dec 24, 2003 | 12:15 AM
GhosTRydeR_92
Default Re: Interior Lighting (Mr Mojo)
my 92 seat control illumanates not sure abou the later years :skep:
Old Dec 24, 2003 | 07:37 AM
Mr Mojo's Avatar
Mr Mojo
Default Re: Interior Lighting (corvetteman_340rwhp)
I'll have to check it out, I know as far as '91 they did.
Old Dec 24, 2003 | 04:14 PM
CaliforniaVette
So i have to take to whole console off?
Old Dec 24, 2003 | 05:00 PM
GhosTRydeR_92
just the console place yes there screws that hold it down under the console lid toward the front 2 of them and then u have one screw in the cup holder area jus one if u have a auto u have to some how pull the button up out of the shift **** it just pulls out then u got a snape ring that holds the **** on then when u pull the plate up shift it into neautral make removing the plate easier then u have 2 terminals that connect to the trunk release in the console disconnect those and then twist the light bulb out of the shift indicator iluminator remember to besure and put the shift indicator back on the pin so your indicator marker will work that should do it for the removal for the console now on the seat controler i think u might have 4 screws that hold it on remove those and turn it over u will see a lil grey circler thing on there u have to twist it out clock wise and there is your bulb keep in mind the grey thing maybe a differ color to maybe blue or black somewhere along that line and there ya are thanks dax :thumbs: happy holidays
Old Dec 24, 2003 | 08:49 PM
CaliforniaVette
Thanks, so i got everything off and had alot of trouble trying to get the powerseat thing disconnected because the wires were to much trouble, maybe ill do it later. so is this lit up by bulbs or LED? looks like LED but i wasnt sure i didnt have alot of space to look
Old Dec 25, 2003 | 12:31 AM
GhosTRydeR_92
they are lit up by bulbs hmm leds hmmmm u gave me a awesome idea thanks ! :party:
Old Dec 25, 2003 | 06:23 PM
SPEED750's Avatar
SPEED750
On my 92 that center piece between the seat controls will pop out.You might be able to replace bulbs thru that hole.LEDs are not a good idea.They don't put out enough light.Even the super bright ones focus the light straight ahead.
I tried replacing my cargo lights with 2 , 4 LED units.They didn't reflect enough light out the lenses. :(
Old Dec 25, 2003 | 07:06 PM
GhosTRydeR_92
Default Re: Interior Lighting (SPEED750)
the bulbs in seat controls and window controls ne thing on your door panels or console are off light emeting into a clear plastic that directs the light where to go LEDS will work in this situations b/c like u said leds light is emitted on top of the bulb so it would work ! :cheers: happy holidays thanks dax !
Old Dec 26, 2003 | 10:07 AM
DarkHalo's Avatar
DarkHalo
From: SCMR Rat Pack'r Charter Member, Inland Empire Chapter
I havent dug into exactly that part of the console yet but Ive had it apart all around it at times and on my '91 its lighted. If you need more room you might want to pull the drivers seat out. Believe it or not it only takes about 5 min to pull the whole unit out.
Old Dec 26, 2003 | 02:28 PM
CaliforniaVette
Default Re: Interior Lighting (DarkHalo)
I dont see why the seat would need to be pulled? i got everything out just fine :)
To Interior Lighting
