insterment cluster
Old Jan 19, 2004 | 12:25 AM
southern vette91
Default insterment cluster
is the millage held in the cluster i need to swap mine out bad gauges and display but i have low millage and dont want to loose it thanks
Old Jan 19, 2004 | 12:36 AM
bogus's Avatar
bogus
Default Re: insterment cluster (southern vette91)
its stored in the ccm, I am pretty sure.
Old Jan 19, 2004 | 12:39 AM
GhosTRydeR_92's Avatar
GhosTRydeR_92
Default Re: insterment cluster (bogus)
NO the mileage is stored in the bcm (body control module ) :thumbs:
Old Jan 19, 2004 | 12:46 AM
JOliver's Avatar
JOliver
Default Re: insterment cluster (corvetteman_340rwhp)
You can swap it out no problem...You have bad gauges ??? I'd check my connections before I bought another unit....Unless you've doen some wire swapping and smoked the unit I haven't seen very many that have had serious problems.I've seen a few with some bad/corroded connections but never a truly burned display ...for the 90-96s that is.
Jason
VetteInstruments@aol.com
Old Jan 19, 2004 | 07:20 PM
AverageVetteNut's Avatar
AverageVetteNut
Cruise-In 9-10 Veteran
CI-X Auto-X Champ (race tires)
St. Jude Donor '07-'09
Well, if it is the same as the rest of GM vechiles, if you swap out the cluster, it will have different miles on it. I talked to my Chevy dealer about swapping out my guage cluster in my 01 Silverado for a white faced kit, and they said that if I swapped just the FACEPLATE, that it was ok, but the actual guage cluster would have 0 miles ( providing it's brand new ) on it, and wouln't reflect my actual miles.
Now, that's not to say that older GM vechiles are the same way, but I would think it's similar like back in teh day when the analog guages with odometers were all like that as well.
Feel free anyone to correct me on this. I'm a bit curious myself.
:hat
To insterment cluster
