Fuel filter
Old Jan 23, 2004 | 06:57 PM
VettBrat's Avatar
VettBrat
Default Fuel filter
Where is the fuel filter on an 86?
Old Jan 23, 2004 | 07:04 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Default Re: Fuel filter (VettBrat)
If it's like my '95 it's under the car behind the RF wheel.
Old Jan 23, 2004 | 07:43 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
87, behind the RF tire attached to the frame :thumbs:
Old Jan 23, 2004 | 08:29 PM
onrecess's Avatar
onrecess
If you plan on replacing it, read how first or expect a giant fuel spill, maybe even a nice toasty fire... The filter is under pressure.
Old Jan 23, 2004 | 09:08 PM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
Default Re: Fuel filter (onrecess)
I agree should be under passenger side door..towards the engine. You will need to pull the fuel pump fuse, run it until it stops, and then relieve the pressure at the fuel rail. Be warned though...you may never be able to get the flow of gas to stop at the filter.....I ended up filling 5 2 liters full of fuel before I gave up. I ended up driving it until it almost ran out of fuel and then changed it......good luck
Old Jan 24, 2004 | 12:29 AM
vinnies87's Avatar
vinnies87
Default Re: Fuel filter (Bruthish)
get some plastic plugs (tapered) and install in both line ends .... only lost a little that way.... :thumbs:
To Fuel filter
