VATS System
Old Jan 25, 2004 | 04:14 PM
TurismoVette's Avatar
TurismoVette
Default VATS System
Every Sunday I go out and wash my 87'. So I moved my parents cars so I could pull mine out of the garage. When I went to start it up, the VATS would not let me:mad ??? I know the battery is not dead because it has done this once before.... The first time it did not start I thought it might have been the key so I went and bought another one, but I guess not :sad:. So, what could it be? Thanks for the help!
Old Jan 25, 2004 | 07:25 PM
JIMKC4's Avatar
JIMKC4
Default Re: VATS System (TurismoVette)
When mine acted up, I could temporarily fix by cleaning the lock cylinder inside contacts with a q-tip and alcohol. I eventually had the lock cylinder replaced.
Old Jan 25, 2004 | 08:15 PM
TurismoVette
Default Re: VATS System (JIMKC4)
Well 10 minutes later I went out and tryed it again and started right up. :skep: While I was washing my Vette I think every car slowed down to look at it. :yesnod: :yesnod: Since it is a C4 I never thought people would check it out so much. :thumbs:
Old Jan 27, 2004 | 01:51 AM
thnbluline50's Avatar
thnbluline50
Ecklers sells a bypass switch for 25.00. It installs in 5 min but you will lose the security of the VATS system
Old Jan 27, 2004 | 05:31 PM
TurismoVette
Default Re: VATS System (thnbluline50)
I just got a Corvette Central catalog in yesterday and they had a bypass that you can switch the VATS system on or off. It sells for $55.... Not too bad.
Old Jan 27, 2004 | 06:12 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Replace with same one as you listed... and it works great, VATS enabled, total disable, or NO Vats.... so if your key dies, you switch to NO VATS and away you go... :thumbs:
Old Jan 28, 2004 | 02:21 PM
sraft's Avatar
sraft
Default Re: VATS System (vinnies87)
This is a problem on early C4s and I believe that Chevy made improvements in '88. My friends '86 was doing the same, then got progressively worse and wouldn't start in damp/humid weather. He was so afraid of being stranded that he used to leave the car unlocked so that the VATS would stay inactive. Ultimately he replaced the ignition lock cylinder and had a new key made, and the problem dissapeared. The new lock cylinder and key were ~$70 (not including labor), but this should be a reasonable DIY.
To VATS System
