Spark checking device?
Old Feb 2, 2004 | 01:42 PM
B84RADR's Avatar
B84RADR
Default Spark checking device?
Gentlemen,
I heard that there are some devices you can buy from Jegs or Summit that will help you check for spark to each of your cylindars one at a time. Do you know if such a thing exists?
I'm asking because I'm missing somewhere. I replaced all of the spark plugs and cables and I'm still missing, but I can't tell where. Any advice?
Thanks!
Shayne
Old Feb 2, 2004 | 01:48 PM
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
Default Re: Spark checking device? (sspackman)
I don't know about Corvettes but when I was a kid my father used to check the spark on our lawn mower by having me hold the wire connector. That technique only worked a couple times though: "Once sparked, twice shy"...
Old Feb 2, 2004 | 01:57 PM
B84RADR's Avatar
B84RADR
Default Re: Spark checking device? (tobijohn)
... by having me hold the wire connector. That technique only worked a couple times though ...
OUCH that SUCKS!!!! You're kidding right? ;)
Old Feb 2, 2004 | 02:04 PM
tobijohn's Avatar
tobijohn
Bench Racer
:lol: No, I wasn't! My father thought it was hilarious. I didn't think it was so funny at the time but that didn't keep me from trying it on my younger brother several years later. And I believe he had our kid brother hold the wire a few years after that. I guess it's become a Tobin family tradition. Both my brothers have sons so I assume a few years down the road, they'll get an opportunity to check for spark as well... :)
Old Feb 2, 2004 | 03:13 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
haven't heard of one,,, you can use the old, remove boot and hold screw driver and see if you get a spart.... :thumbs:
Old Feb 2, 2004 | 07:30 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: Spark checking device? (vinnies87)
Pull the wire and unscrew the spark plug, then hook it back up, ground the plug against something, like the head, disconnect the fuel pump fuse and have someone crank the engine over (just crank, it shouldn't start). It helps if its a little dark in there, easier to see the spark.
The other way, is to get a timing light. These cost $40-$80 thereabouts. Hook it up to the battery, stick the inductive clamp on the plug wire in question, and start the engine, the timing light should flash everytime the spark plug on that wire, well, sparks. This is the easy way to do it... and the timing light is a a basic necessity for the car DIY'er. You'll need one eventually anyways, so it's worth the purchase.
Old Feb 2, 2004 | 08:06 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I've got a little inductive indicator that was a promotional Champion item that I've had for at least 25 years. Looks like a pen, just lay the tip on the wire. Surely something like that is still made.
Old Feb 2, 2004 | 09:34 PM
Jim Sitton's Avatar
Jim Sitton
Default Re: Spark checking device? (Corvette Kid NC)
Most auto parts stores sell a spark checking device that has an adjustable gap that will not only tell you if you're getting spark but you can adjust the gap until it just stops sparking and a calibrated scale on the checker actually measures the spark voltage. This is much better than just checking for spark on a removed plug. With a weak spark, the plug may spark in ambient air but may not in the more sever envrionment of the combustion chamber.
To Spark checking device?
