Tune up advice needed
Old Feb 3, 2004 | 01:54 PM
quantum-theory's Avatar
quantum-theory
Default Tune up advice needed
I want to get my new 87 with 56k miles running great. I believe the car is totally stock and I am wondering what are the best parts to use. I keep reading on the forum about spiro pro wires, NGK plugs etc. Am I best off just using stock delco parts or is there an advantage to using other makers parts?
Thanks for the advice.
Old Feb 3, 2004 | 02:02 PM
03whitecoupe's Avatar
03whitecoupe
Default Re: Tune up advice needed (quantum-theory)
If you want to keep it basically stock and aren't into performance mods, then AC Delco is more than adequate for that. That's all I use but I'm not a performance mod kind of owner. It'll usually save you money too.
Old Feb 3, 2004 | 03:41 PM
redwing76's Avatar
redwing76
I use Autolite plugs. They'll out last any other plug out there.
Cut the air filter cover and get a K&N filter. Replace the cap and rotor if it needs it.
If you need tires buy Kuhmo's.
Old Feb 3, 2004 | 06:08 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
MDS 8mm, AC delco cap & coil, AC Delco spitfire plugs, cut your air filter cap, and you can use regular filters... For a stock system, there is really no advantage to go otherwise... :thumbs:
Old Feb 3, 2004 | 06:32 PM
quantum-theory
Default Re: Tune up advice needed (vinnies87)
When you say, "cut the air filter cap," what do you mean?
It's starting to look like your telling me to stay with AC delco - correct?
To Tune up advice needed
