factory security system
Old Feb 7, 2004 | 01:51 PM
vetteboy88's Avatar
vetteboy88
Default factory security system
The factory security system on my c-4 cannot be disarmed on the drivers side, just the passenger door...Any ideas on what to check?????
Old Feb 7, 2004 | 04:25 PM
86PACER's Avatar
86PACER
Default Re: factory security system (vetteboy88)
Yeah, pull the door panel and look at the lock cylinder of the door handle. Check the wire and make sure the mechanical rods are connected properly. Insert the key and turn it while you look at the lock cylinder from the inside of the door with the panel removed. If you are not sure how the rods should be operating and connected, pull your passanger side and see how that one is.
Old Feb 8, 2004 | 02:57 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I had that problem, but it was simply bad contacts in the door lock. I pulled the door panel off and cleaned out the backside of the lock asssembly. When you turn the key, it grounds a contact in there with disarms the system.
Old Feb 8, 2004 | 09:48 AM
rick lambert's Avatar
rick lambert
Default Re: factory security system (CentralCoaster)
I had problems with mine and went after market, Avital, installed by Best Buy,
I love it :D remote, backup battery, opens hatch, lets me know if a bird pooped on it :lol: this summer I'm replacing that wimpy horn-Best Buy did a great job, would recommend them :thumbs:
Old Feb 8, 2004 | 04:12 PM
CentralCoaster
Default Re: factory security system (rick lambert)
Yeah.. but can you turn on the stereo with it? :D I stopped just short of having a function to open the windows.
Old Feb 8, 2004 | 04:28 PM
86PACER's Avatar
86PACER
Remote activated Stereo. That's pretty slick. :cool:
To factory security system
