Installing EGR.
Old Feb 12, 2004 | 11:21 PM
CRVETTE92's Avatar
CRVETTE92
Default Installing EGR.
Before i go messing with this i just want to make sure they are'nt any special tricks to remove and install an EGR valve seeing as is i'm getting a code 32.
:flag :seeya
Old Feb 12, 2004 | 11:33 PM
bogus's Avatar
bogus
Default Re: Installing EGR. (CRVETTE92)
Ok... a bit of help for ya here.
Does the light come on at start up, or, after a short drive?
If it comes on at start up, the problem is with the EGR circuit, not necessarily the valve.
If it comes on after a short drive, then it's only the valve.
Replacing the valve can be a bit of a pain. The EGR is held on with 2 10mm bolts. The pain is this: There is sooo little room, a ratchet won't fit. I found that a geardrive wrench is the best tool.
The gasket may stick to the intake... thanks to the lack of space, I simply hit the valve with a very thin skim of RTV and reused the gasket.
That should about cover it.
Old Feb 12, 2004 | 11:39 PM
GhosTRydeR_92's Avatar
GhosTRydeR_92
Default Re: Installing EGR. (bogus)
rachet wrenchs are :cool: got me a set of snap ons for nearly nothing :jester
Old Feb 13, 2004 | 02:34 AM
CRVETTE92's Avatar
CRVETTE92
Default Re: Installing EGR. (GhosTRydeR_92)
It must be the valve 'cause the "service light" comes on after about 30-45 min of sustained driving.
Old Feb 13, 2004 | 07:03 AM
1990CORVETTE's Avatar
1990CORVETTE
You know BOGUS, that is the first time since I have been on this forum, that I have ever heard it explained that way,,,,, THANK YOU very much,,,,, After all the changing and buying parts,,,,, you have solved my problem,,,,,,, My car after a drive the light comes on,,,, I have been told so many things , nad I have changed so many things,,, except the EGR valve,,,, gonna do that now................ :D
Old Feb 13, 2004 | 09:00 AM
86_RedRider's Avatar
86_RedRider
Cruise-In V Veteran
St. Jude Contributor '03 & '05
oh dear old code 32, one of these days i'm just going to rip that whole egr system out.
Old Feb 13, 2004 | 09:03 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
:thumbs:
Old Feb 13, 2004 | 11:06 PM
86_Vette's Avatar
86_Vette
Default Re: Installing EGR. (vinnies87)
When I went to check my EGR sensor, I come to find out that the wire had broke off between the engine and firewall. :banghead: One of these day, I'm going to either reconnection that wire or just rip out the entire EGR system
[Modified by 86_Vette, 11:06 PM 2/13/2004]
Old Feb 14, 2004 | 12:54 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
How offten should it be changed?
Passed smog last month. Test only station.
So do I need to cange at 89k miles or what?
thanks
tony
:cool:
Old Feb 14, 2004 | 09:09 AM
ittlfly's Avatar
ittlfly
Default Re: Installing EGR. (oldace84)
thanks
tony
:cool:
I think that this is one of the case that if it aint broke, don't fix it. :D
To Installing EGR.
