Engine compartment Lights.
Old Feb 13, 2004 | 03:27 PM
lbitp37's Avatar
lbitp37
Default Engine compartment Lights.
A while ago I asked how to turn the light off,especially when the hood is open for a long time, as in a show.
Many replied to disconnect the fuse, but I found a better way.
1.Open hood
2. Disconnect the fuse connection,there is one on each side.
3. There is a pair of wires coming from the lights down to the fuse connection.
4. Cut one of the wires in a convient place.
5. Buy an insulated set (male / Female), of spade connectors.
6. Crimp them on each end of the wire you cut.
7. Re-connect the fuse plug,then plug the male/female together.
Total cost= $.72, Total time 5 mins/side,and Now there is no fishing around for the fuse conection..
[Modified by lbitp37, 3:29 PM 2/13/2004]
Old Feb 13, 2004 | 03:34 PM
Wayne88's Avatar
Wayne88
Default Re: Engine compartment Lights. (lbitp37)
I followed the wire from the light, down to the connector [ near the headlight],
and just disconnected it. Simple & costs $0.
:U - maybe I'm wrong???
Old Feb 13, 2004 | 03:42 PM
corvettemaster's Avatar
corvettemaster
Default Re: Engine compartment Lights. (Wayne88)
:iagree: that's what i do. maybe it's different on the newer c4's?
Old Feb 13, 2004 | 04:19 PM
85 Stalker's Avatar
85 Stalker
Take it to the next step and install a simple toggle switch. That is my project as soon as it warms up a little bit....
Old Feb 13, 2004 | 05:04 PM
Red Guts's Avatar
Red Guts
Default Re: Engine compartment Lights. (corvettemaster)
:iagree: It's the same on the newer C4s. Just pull the plug. No cutting necessary.
Old Feb 13, 2004 | 05:26 PM
lbitp37's Avatar
lbitp37
Default Re: Engine compartment Lights. (85 Stalker)
Toggle switch might be nice, but 1st, where do you mount it,2nd it will corrode.
My solution is a very simple solution and task. !!
Old Feb 13, 2004 | 05:59 PM
85red_vette's Avatar
85red_vette
I installed a small toggle switch to cut off both lights.
I put the switch in a small plastic box
attached to the inner fender wall
Works fine no problems.
[Modified by 85red_vette, 5:00 PM 2/13/2004]
[Modified by 85red_vette, 5:01 PM 2/13/2004]
[Modified by 85red_vette, 9:53 PM 2/14/2004]
[Modified by 85red_vette, 9:55 PM 2/14/2004]
Old Feb 14, 2004 | 10:41 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
You can mount it/them anywhere and they will be far less suseptible to corrosion than exposed spade connectors. I put rocker switches in mine, mounted under the hood, they look 'professional', and they work beautifully...one finger operation. Quick. Easy.
Larry
code5coupe
:seeya
Old Feb 14, 2004 | 10:54 PM
JB666's Avatar
JB666
Default Re: Engine compartment Lights. (rocco16)
Someone on the forum installed a cool toggle switch, and had very clear pictures posted... Maybe he'll come in. :thumbs:
Old Feb 14, 2004 | 11:07 PM
TA's Avatar
TA
Same here................follow the wire and unplug :confused:
Old Feb 15, 2004 | 10:05 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Have the same setup....and works great.... :thumbs:
Old Feb 15, 2004 | 08:33 PM
Dandy97's Avatar
Dandy97
:withstupid:
Old Feb 15, 2004 | 08:42 PM
Preacher's Avatar
Preacher
Cruise-In IV Veteran
I did that about a year ago. Secured the light to the inside of the fender right by the fuse. Now I just hit the button and the lights go out. Easy as pie and not a ghetto as having to pull the fuse. :thumbs:
Found this paint drawing I did when I posted about it a year ago..
To Engine compartment Lights.
