Scratch Removal
Old Feb 16, 2004 | 05:14 PM
KWP's Avatar
KWP
8th Gear
Default Scratch Removal
I have recently purchased a black '96 that has a swallow scratch I'd like to remove. Any suggestions as to procedures or products that work?
Old Feb 16, 2004 | 05:40 PM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
Default Re: Scratch Removal (KWP)
welcome to the forum!
You came to the right place for questions like this. Someone with a better answer than I could give will jump in soon..........
Old Feb 16, 2004 | 05:49 PM
HammerDown's Avatar
HammerDown
I'd ask this question in the Car Care Products forum. You're going to have to give them more details about the scratch in order for them to properly advise you on the products and techniques needed to remove it.
Welcome to the forum! :seeya
Old Feb 16, 2004 | 05:53 PM
-=Iron Mike=-'s Avatar
-=Iron Mike=-
Default Re: Scratch Removal (brdd)
I've had some luck with wax products designed to hide the blemish (if the scratch isn't too deep) It does require constant application to keep looking good though (like every week) I'm planning on wet sanding this spring ( If I get the nerve up) it's about the only way I know of besides a re-paint.
:lurk:
Old Feb 16, 2004 | 06:01 PM
blk90rdstr's Avatar
blk90rdstr
Default Re: Scratch Removal (Irish Mike)
Im not too familiar with thw swallow scratches, but if you mean shallow scratch, you can machine buff it out with a medium compound then re-wax whole car. There are some petrolium/silicone products that mask the scratches but they are temporary and dont always fully remove it. Just be carefull you dont buff thru the clear its easier to do on an older car. :cheers:
Old Feb 16, 2004 | 06:07 PM
KWP's Avatar
KWP
8th Gear
Default Re: Scratch Removal (blk90rdstr)
Ha! I didn't even catch the typo. I'm not familar with that kind of scratch either!! Thanks for the response.
Old Feb 16, 2004 | 06:11 PM
wmrobert's Avatar
wmrobert
I'd use factory touch-up paint and langka. It won't be 100% but it will look very acceptable. :thumbs:
Old Feb 16, 2004 | 07:44 PM
Jet-Jock's Avatar
Jet-Jock
If the scratch is just in the clear coat you can probably remove it using 3M's Finese-it II. You can pickup a bottle at your local automotive paint dealer. This is what the shops use. If your not experienced with a buffer, I'd recommend rubbing it out by hand. Finese-it is basically a 2000 grit liquid sand paper. If your concerned about having it done right and not damaging the finish you might stop by a good paint shop (dealer or 3rd party) and see what they'd charge you to buff it out. Probably won't be much.
Afterwards if your not a Zaino user you can consider using the Z5 with its scratch and swirl mark remover to finish it up. After a few applications most of all those micro fine scratches you can see by tilting your view angle under the lights will be gone. Its not permanent, so as the Z5 wears off repeat applications restores the mirror finish minus the micro scratches.
Hope that helps. :seeya
Old Feb 17, 2004 | 08:36 AM
GrEeNdAyZ's Avatar
GrEeNdAyZ
Default Re: Scratch Removal (wmrobert)
http://www.langka.com/newsite/index2.html
Old Feb 17, 2004 | 09:55 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
1st welcome...Had some good suggest given.... :iagree:
Old Feb 17, 2004 | 12:12 PM
redwing76's Avatar
redwing76
Go to a automotive paint dealer and get a pint of black single stage paint and a small artist brush apply several coats with the brush wait a week of so and repeat the process till the stratch is higher than the rest of the paint.
After the paint shrinks apply rubbing compound with your finger till it matches and then polish the area.
The trick is to build up the stratch.
Old Feb 18, 2004 | 12:08 AM
Wayne88's Avatar
Wayne88
Default Re: Scratch Removal (redwing76)
If the scratch is deep, {past the paint}.
Find a professional detailer/painter and pay him to restore it.
If its a nice Corvette, don't cut corners.
:cool:
To Scratch Removal
