~~Fuel filter replacement Questions~~
Old Feb 17, 2004 | 07:07 PM
USA-VET's Avatar
USA-VET
Default ~~Fuel filter replacement Questions~~
I want to replace the fuel filter on my 96 LT1, Is it a easy task? If I take it in to the shop what is a fair price to pay for the job. I see that the filter only cost $15. :flag
Old Feb 17, 2004 | 07:41 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Default Re: ~~Fuel filter replacement Questions~~ (bigbozman)
It's simple, just jack the front of the car up, and make sure you have the correct line wrenches. Will take you all of 10 minutes if you are slow.
Old Feb 17, 2004 | 07:48 PM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
Default Re: ~~Fuel filter replacement Questions~~ (Jeffvette)
Just make sure you use backup wrenches. If the filter's been there awhile, it's going to be tough to get off. And it's real easy to strip the lines. Otherwise, as said, it's an easy job.
Also, make sure you depressurize the fuel system. That means you have to pull the fuel pump fuse, start the car, and let it run out of gas. Then, you're good to go. Failing to do this will spray fuel everywhere. Not good.
Old Feb 17, 2004 | 09:37 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Really, quite simple and straitforward.
Good Luck
tony
:rolleyes:
Old Feb 17, 2004 | 09:46 PM
Midnite 88's Avatar
Midnite 88
Default Re: ~~Fuel filter replacement Questions~~ (oldace84)
If you have a fuel pressue guage with the bleed off button you can depressurize the system with it. Or a screwdriver and some shoptowels. Just make the motor not hot.
Mike.
Old Feb 17, 2004 | 10:17 PM
clubvette's Avatar
clubvette
Default Re: ~~Fuel filter replacement Questions~~ (Midnite 88)
:iagree:
Old Feb 17, 2004 | 10:54 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
:iagree: :thumbs:
Old Feb 18, 2004 | 12:44 AM
Wayne88's Avatar
Wayne88
Default Re: ~~Fuel filter replacement Questions~~ (vinnies87)
I've done it on other cars, not my Corvette.
Expect to get a gas shower, wear glasses over your eyes, you might get splashed.
Other than that, fairly basic & easy.
:cheers:
Old Feb 18, 2004 | 01:22 AM
JasonL's Avatar
JasonL
It's a bit trickier on the LT1 because of the passenger side cat.
You may find it easier to disconnect the rear fitting, pull the fuel line in to the engine bay and rest the filter/line on the tire. Then you have easy access to the front fitting.
As mentioned, make sure the car is cold since you will have gas fumes everywhere.
Old Feb 18, 2004 | 02:31 PM
CaliforniaVette's Avatar
CaliforniaVette
Default Re: ~~Fuel filter replacement Questions~~ (JasonL)
I did it on my LT4... i now have a chemical burn on my arm from prolonged exposure to gasoline... :nonod: but its healing :)
Old Feb 19, 2004 | 12:19 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Default Re: ~~Fuel filter replacement Questions~~ (CaliforniaVette)
Gotta love the burn of MTBF in the ol' armpit! :smash:
-JRC-
To ~~Fuel filter replacement Questions~~
