Passive keyless Entry - 94 vet
Old Feb 22, 2004 | 11:12 AM
Pshadow194vet's Avatar
Pshadow194vet
Cruising
Default Passive keyless Entry - 94 vet
My passive keyless entry stopped working and the light came on in the center display. Has anyone else had this problem?
Old Feb 22, 2004 | 01:46 PM
sraft's Avatar
sraft
Default Re: Passive keyless Entry - 94 vet (Pshadow194vet)
Welcome new member!
If you're lucky, it's become unprogrammed or you accidentally disabled the system. The owner's manual has the steps for turning it back on and for reprogamming the fob to the car.
If you're unlucky (like I was) the PKE receiver, which is buried under the dash, has gone bad and needs replacement.
Old Feb 22, 2004 | 02:53 PM
Pshadow194vet
Cruising
Thanks for the quick response.
I had actually reprogrammed the fob on a couple of times and like other posts it worked for a short period. After the last programming stopped working the light came on and has remained on. Since the transmitter will not work I cannot try turning the system on . Does this sound similar to your problem?
Did you replace the receiver yourself or pay to have it done? If you don't mind, what did it cost you?
Thanks,
Old Feb 22, 2004 | 03:00 PM
FD2BLK's Avatar
FD2BLK
Have you tryed replacing the batery in the FOB yet?
BTW/ I posted FOB programing instructions in the tech section but don't know if they are there yet.
[Modified by 84LT1, 2:01 PM 2/22/2004]
Old Feb 22, 2004 | 03:41 PM
sraft's Avatar
sraft
Make sure you've replaced the fob battery before you go further.
I replaced the receiver myself. You have to remove the dash cap - the PKE receiver is located behind the radio/heater controls. It's a PITA job and you have to be very careful not to pull on the dash before ALL the fasteners and tabs are off or else you end up breaking these connecting points and the dash will squaek and rattle. I went real slow and careful and it took a whole weekend to do it the first time, but now that I'm familiar, I could probably do it in 4 hours.
The PKE receiver goes for ~$200 at the dealer, but I got lucky and found an unused one on ebay for $50.
Old Feb 22, 2004 | 04:33 PM
Pshadow194vet
Cruising
Default Re: Passive keyless Entry - 94 vet (sraft)
Replaced the battery and no changes. Still does not work.
It is very similar to another post that said he had to replace the receiver. I am going to install a new radio since my CD is not working so I will also replace the receiver. Sounds like that will fix the problem.
Thanks,
Paul
Old Feb 22, 2004 | 05:38 PM
HTRK-1's Avatar
HTRK-1
Thanks,
Paul
:iagree:
To Passive keyless Entry - 94 vet
