Really easy, dumb question.
Old Feb 23, 2004 | 09:21 PM
Chosen Won's Avatar
Chosen Won
Default Really easy, dumb question.
I have a 90 vert, with no owners manual. Couple easy questions.
Where is my jack located? I have found my lug wrench behind the driver's seat, but can't find the jack.
How do I get to the spare tire? I know there is one under the back, but don't know how to get it out.
Someone please enlighten me. Thanks.
Old Feb 23, 2004 | 09:25 PM
89Corvette6spdFX3's Avatar
89Corvette6spdFX3
Default Re: Really easy, dumb question. (Chosen Won)
Never had to change the tire. I should probably look for mine too! I think I've seen all components under the driver's seat. Your jack might be missing.
Old Feb 23, 2004 | 09:31 PM
Chosen Won's Avatar
Chosen Won
Default Re: Really easy, dumb question. (89Corvette6spdFX3)
If it's under the driver's seat, how do you get to it? I can't say I have ever looked under there for anything besides a fry or my stereo remote. :D
Old Feb 23, 2004 | 09:32 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
All I have is an '84, jack under the hood. I think, never used it though.
Good Luck
tony
:thumbs:
Old Feb 23, 2004 | 10:10 PM
Chosen Won's Avatar
Chosen Won
Default Re: Really easy, dumb question. (oldace84)
So does that mean mine is under my hood somewhere? How about getting the sapre out? Someone? Please? :confused:
Old Feb 24, 2004 | 12:30 AM
jdog0411's Avatar
jdog0411
I know there is someone out there with a 90 owner's manual that can help this guy out.
Old Feb 24, 2004 | 12:52 AM
Z51JEFF's Avatar
Z51JEFF
Default Re: Really easy, dumb question. (jdog0411)
The jack should be located with the tire in the tire well,attached to the rim. You will see a nut at the back of the tub closest to the bumper Use the jack wrench to lower the spare tire tub down enough to where you can push up on the tub,when you can push up on the tub the nut-T jobber will release.Pull it towards you while supporting the tub and once the T is out of the way the tub is free to drop down.
Old Feb 24, 2004 | 02:22 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: Really easy, dumb question. (z51jeff)
:iagree:
Old Feb 24, 2004 | 02:58 AM
86PACER's Avatar
86PACER
Default Re: Really easy, dumb question. (vinnies87)
:iagree:
Old Feb 24, 2004 | 06:19 AM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
One thing to add to what has been said, there should be a light bulb right next to the nut so that you can change the tire in the dark. It comes on by turning the dash dimmer untill the interior lights come on. The bulb gets broken a lot so you might just see the socket with the base of a bulb showing.
Old Feb 24, 2004 | 06:38 AM
TA's Avatar
TA
That's where mine is, errr I mean used to be :leaving:
Old Feb 24, 2004 | 09:28 AM
Chosen Won's Avatar
Chosen Won
Default Re: Really easy, dumb question. (TA)
You guys rock, thanks!
Old Feb 24, 2004 | 09:36 AM
86_RedRider's Avatar
86_RedRider
Cruise-In V Veteran
St. Jude Contributor '03 & '05
i keep mine in the compartment in the hatch.
To Really easy, dumb question.
