REGUARDING C4 ENGINE FIRES, EVERYONE READ!!!
Old Feb 28, 2004 | 09:07 PM
  #41
Netnarc2's Avatar
Netnarc2
Default Re: REGUARDING C4 ENGINE FIRES, EVERYONE READ!!! (VtVette)
VtVette, thanks for the info. I have an '85. I'll check it next time I'm inside the hood. :thumbs:
Old Mar 1, 2004 | 06:52 AM
  #42
Atok's Avatar
Atok
Default Re: REGUARDING C4 ENGINE FIRES, EVERYONE READ!!! (iceman_t1)
Is that on the back or the front of the engine? Can anyone confirm if the LT1 uses this same design?
My LT1 is a different design. Fuel lines run up the passenger side back of the engine and are steel / steel braid.
Old Mar 1, 2004 | 01:01 PM
  #43
Iroc's Avatar
Iroc
Default Re: REGUARDING C4 ENGINE FIRES, EVERYONE READ!!! (Netnarc2)
Just checked mine today, rubber hoses look ok, but there are 2 metal edges very near the hoses, guess given enuf time they might wear through the hose.
Old Mar 1, 2004 | 01:09 PM
  #44
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
Thanks for a great tip. I will follow up on this one ASAP.
Old Mar 3, 2004 | 09:36 AM
  #45
madmike's Avatar
madmike
dang, those look really hard to get at :banghead: Im gonna try to check it out today. Im interested in retrofit braided hoses too preferrably with some kind of insulation to keep them cool. Or maybe even curved steel hoses fabricated to fit exact. Why are these hoses made of rubber? Is it where the body of the C4 connects to the engine for engine stumble purposes? Best bet would be insulated hoses. I think the heat destroys to rubber prematurley. :seeya :hurray:
Old Mar 3, 2004 | 06:38 PM
  #46
larryfs's Avatar
larryfs
Default Re: REGUARDING C4 ENGINE FIRES, EVERYONE READ!!! (madmike)
there is a recall for the fuel line
Old Mar 3, 2004 | 11:24 PM
  #47
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default Re: REGUARDING C4 ENGINE FIRES, EVERYONE READ!!! (bogus)
that is an issue with L98 cars... LT1 cars have another problem... the electrics behind the battery get nasty and short out.
After I burned out my fusable link for the 4th time I rerouted it.
BTW if you let you battery get to low the fusable will burn itself out.
Old Mar 4, 2004 | 07:43 AM
  #48
85vet's Avatar
85vet
Cruise-In V Veteran
Default Re: REGUARDING C4 ENGINE FIRES, EVERYONE READ!!! (BrianCunningham)
If interested, I might still have the lines that I recently replaced. GM no longer makes them - had to buy from junk yard.
Email me at: vet85us@yahoo.com
I was not happy that new lines are not available :mad .
Old Mar 4, 2004 | 08:35 AM
  #49
VB Black Ice's Avatar
VB Black Ice
:eek: WHOA! Good timing bud! I recently noticed a serious decrease in MPG and did notice a fuel smell under my hood. I'm going to check that one out when I get home!
Old Mar 4, 2004 | 07:04 PM
  #50
GRX's Avatar
GRX
Great topic! I need to address this issue.... :lurk: ...I would purchase the kit...
[Modified by GRX, 4:05 PM 3/4/2004]
Old Mar 4, 2004 | 09:05 PM
  #51
Denney's Avatar
Denney
Default Re: REGUARDING C4 ENGINE FIRES, EVERYONE READ!!! (GRX)
I'm surprised someone didn't mention this before but, IF you ever run into a situation where you have a fire (smoke) under the hood DO NOT open the hood until you have a good fire extinguisher in your hand and ready to unload... rubber fuel lines - another good reason to always carry an extinguisher in your vette... :thumbs:
