Sticky headlight
Old Feb 28, 2004 | 08:43 PM
cam--'s Avatar
cam--
Default Sticky headlight
The right headlight gets stuck about 20% of the time. Sometimes a quick tap on the front will get it to flip back under, other times, if I leave it alone, it will flip itself over by the morning. Is there some other way to make it more reliable?
cam
Old Feb 28, 2004 | 08:53 PM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
Default Re: Sticky headlight (cam--)
I think you have experienced the dreaded bad bushing in the headlight motor. I am pretty sure your year(87) has the gel in the gears which dries and turns to dust. The fix is cheap($5 at ecklers) and it includes nylon bushings that replace the gel. The hard part is getting the headlights off...took me about an hour a side. Good Luck :thumbs:
Old Feb 29, 2004 | 11:08 AM
xlr8nflorida's Avatar
xlr8nflorida
Default Re: Sticky headlight (Bruthish)
:iagree:
Old Feb 29, 2004 | 11:50 AM
Bilyk's Avatar
Bilyk
gel? i'm pretty sure it's just white grease! best bet would be to open up the motor and clean it out
Old Feb 29, 2004 | 11:59 AM
Bruthish's Avatar
Bruthish
Default Re: Sticky headlight (Bilyk)
I am not talking about the grease. The gear sproket is "locked" onto the shaft by a hard gel. Once that gel turns to dust over the years, the shaft will turn but the sprocket/gear will stay in place. Why GM did that is beyond me. Ecklers has nylon replacements(3 per side) that are used where the gel used to be.
Old Feb 29, 2004 | 12:08 PM
ojaijim's Avatar
ojaijim
Just finished replacing the bushings yesterday. Check C4 tech/performance under "headlight" . :cheers:
Old Mar 1, 2004 | 02:02 PM
mphy98's Avatar
mphy98
if its the passenger side, check to be sure the resivor coolent lines werent catching it. thats what mine was. a simple fix
To Sticky headlight
