wheel question.....................
Mar 3, 2004 | 06:52 PM
Ive got a friend that doing some work on a 85 thats got 17-11 ZR1 wheels with 315s and the cars lowered and the tires tuck into the wheel well,yet ive seen ZR1 wheels on some Vettes and they stick out.Whats the story with that.
Mar 3, 2004 | 07:03 PM
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: wheel question..................... (z51jeff)
:cheers: I think your friend will need to use spacers behind the wheels to get them out.
Rear end set up on ZR1 was wider, I believe, but I could be wrong
:seeya
:steering:
Mar 3, 2004 | 07:08 PM
St. Jude Contributor
Re: wheel question..................... (jackdaroofer)
That's right :yesnod: Just look at Scoob's post calling us all "skinny azzed *****" :lol:
And maybe the guy with the 85 doesn't have adapters :confused: Different backspacing...but it should rub at 11in I think :eek:
:cheers:
Mar 3, 2004 | 07:09 PM
An actual ZR1 (rear) wheel has the same offset as 84-87 vettes, so it doesnt need a spacer plate. It should fit fine.
[Modified by vader86, 6:09 PM 3/3/2004]
Mar 3, 2004 | 07:12 PM
Re: wheel question..................... (vader86)
I didn't know that!! :hurray: :hurray: :hurray: Bring 'em on :D
What about the fronts?
Mar 3, 2004 | 07:21 PM
Re: wheel question..................... (JSA 007)
Fronts are 56mm, like 88-96 vettes.
