Coolant Temperature Switch Installation
Old Mar 6, 2004 | 10:57 AM
MaSTeRofDZaSTeR's Avatar
MaSTeRofDZaSTeR
From: "Drive like Hell, you'll get there faster." Tucson AZ
Default Coolant Temperature Switch Installation
I was just wondering where the heck is the Coolant Temperature Switch/Sensor that kicks the fans on at like 180 and off at 220? Is it under the throttle body? I thought I saw it the other day, cuz I wanna replace it, but I think I gotta unbolt the whole throttl body first.
Old Mar 6, 2004 | 11:23 AM
Z51JEFF's Avatar
Z51JEFF
Default Re: Coolant Temperature Switch Installation (MaSTeRofDZaSTeR)
The switch on my 84 is on the right side of the motor.Hope this helps.
Old Mar 6, 2004 | 11:31 AM
HeeHaw89's Avatar
HeeHaw89
Its on the driver side of the block by #3 cyl.
[Modified by HeeHaw89, 11:31 AM 3/6/2004]
Old Mar 6, 2004 | 01:31 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I believe your '90 has two fans behind the rediator; in which case you don't have such a switch. The ECM has sole control over the fans and the on/off points are programmed into the EPROM.
You can install an aux fan switch after removing the plug in the block below #1 & #3 spark plugs. Then wire that new switch per my C4 Tech Tip to turn on both fan relays or only one, as you chose.
Old Mar 7, 2004 | 11:02 AM
MaSTeRofDZaSTeR
Default Re: Coolant Temperature Switch Installation (65Z01)
Wow......I never hear this before. Yes it does have dual fans behind the radiator, but I was never told there's no switch. I'll definitely try what u said if it comes down to it. What I did to fix the prob of the fans continuously running after the engine was killed, was I got a new GM relay and GM relay connector plug-in yesterday cuz I believe a switch may hav just been stuck in the old one which looked fried anyhow. If it isn't the relay or the connector, than it has to be the switch in this case which would probably be the ecm in the EPROM reading like u said. Thanks all and 65Z01 for the info. :seeya
To Coolant Temperature Switch Installation
