Starting problem
Old Mar 12, 2004 | 04:31 PM
Bringin'it's Avatar
Bringin'it
Default Starting problem
I am having a issue with my car starting. When I turn the key (in my '96) I get a click and nothing happens. If I let go and turn it again it starts just fine. It has been sitting quite a bit over the winter and at first I thought the battery charge was low, but it is still doing it now that I am driving it more. It also doesn't do it all the time. I am now starting to wonder if it is a solenoid or possibly a flat spot in the starter. Any ideas ???
Old Mar 12, 2004 | 04:53 PM
rick lambert's Avatar
rick lambert
Default Re: Starting problem (Bringin'it)
First, get your battery checked! You'll probably find out that it's the problem, unless you used a battery tender over the winter. Second, connections-whether you used one or not.Third-GOOD LUCK! :seeya
Old Mar 12, 2004 | 08:00 PM
Stv50's Avatar
Stv50
Default Re: Starting problem (rick lambert)
:iagree:
Time for a new battery.
To Starting problem
