FX3 shock question?
Old Mar 12, 2004 | 10:40 PM
94redrag's Avatar
94redrag
Default FX3 shock question?
I'm replacing the front fx3 shocks on my car due to broken gears on top of the shocks and was wondering if it makes a difference what position the gear is in when you put the actuator back on the shock? Does it make a difference or not? I would hate to have a gear in the wrong position and then when I start the car the actuator breaks the gear off again when it tries to find the correct position. Thanks Zane
Old Mar 12, 2004 | 11:07 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Default Re: FX3 shock question? (94redrag)
Doesn't matter. The acutator cycles to find the end stop each way.
Old Mar 12, 2004 | 11:31 PM
94redrag's Avatar
94redrag
Default Re: FX3 shock question? (Jeffvette)
Thanks Jeff!! Thats one less thing to worry about gettin right! :cheers:
Zane
Old Mar 13, 2004 | 01:16 AM
Pappa_Bear's Avatar
Pappa_Bear
At least you have your actuators. Someone had taken mine off then they had the car serviced back in time. Gonna be fun trying to find some more I suppose. :banghead:
To FX3 shock question?
