quicker targa top removal???
Hey, guys,
Is there an after market product that you can attach that will allow you to quickly remove the targa top, without having to remove the screws each time?
Hey, guys,
Seems much more satisfying to take it off than put it on. :seeya
I'd love a quicker way than ratcheting. It only takes me 2 minutes the old fashioned way, but even that seems too long at times. Here's how I do it now, it only takes me about 1:30. I had a heck of a time finding a long enough T-40 bit. I finally chased down a Snap-on guy while he was getting a coffee at Starbucks. He didn't have a regular bit like this so he removed the bit part from a socket and sold it to me separately. Cost me $15 as I recall. My wife thought I was nuts for chasing the guy into a Starbucks.
Ron
Ron
I ordered mine online from a tool company for about $3. Go to wihatools.com and you can find it, get the longest T40 they have, works great in an electric screwdrive!!
it doesn't really bother me to just take it off with a ratchet, and put it in the back...but putting it back on is another story. not exactly an easy 1-person job like taking it off :banghead:
The Corvette engineers took the targa top removal idea
from the crank on the Model T Ford.
Don't knock-it: This is modern engineering.
[Modified by Wayne88, 2:55 PM 3/19/2004]
there is a product in Mad Vette called, well, basically, it's a power screwdriver with the bit permanently attached. It's rechargable, and fits in the console compartment...
Here's the link to WIHA tools:
http://wihatools.com/745ser90.htm
They have a 3.5" long T40 power drill bit for $3.80. :thumbs:
There just has to be a way to use small clips instead of bolts, the way the front bolts are vertical and the rear horizontal should mean that clips will do the job and hold tight.
Someone here last year reckoned they'd found the answer, then they got lost in the patent machinery etc.-- I'm sorry to say that I can't see there will ever be enough reward for the invention. I hope they do OK but by the time it's markedted C4's will be owned by poor people or treated as Garage Queens, and the market may be lost.
Removing the 4 bolts with the mini rachet machine is easy, but for me, storing it is a big pain - the choice is to put it in the cargo area and loose all the room or leave it at home and see the weather turn dramatically bad... I've done both.
I'm planning to build a 'raincoat' style top that will be held on with the same bolts but will store easily. I'm too mean to buy one - they're over $400.
On almost the same subject, I built a sun shade for the glass top last year that has been on all summer (I'm in the southern hemisphere) it has worked brilliantly and cost very little. I'm up to version 3 and will be trying version 4 soon. When I'm done experimenting I'll post some results.
S'nut
S'nut
