HELP!!!! This is driving me nuts ...
Old Mar 22, 2004 | 02:33 AM
GhosTRydeR_92's Avatar
GhosTRydeR_92
Default HELP!!!! This is driving me nuts ...
ive been having this prob with my vette missing on the driver side bank . at first i had codes which where the 02 sen and KS i replaced both sets . now all the codes are gone an the miss is still there . i dont know what else to do about it ive pulled each plug wire and injector wire while it was running to try to narrow down which cylinder was missing . i cant really tell but its between 3 or 5 cylinder. i checked the spark with a spark tester to and it seems to have plenty of spark on all cylinders. so this narrows it down to fuel . How do i check to see if the injectors are working properly??? :confused: Is there a way to check the wiring goin to the injectors ??? :confused: how do i test it with a volt meter ?? I hope some one can help me this is really drivng me nuckin futs :banghead: :banghead:
Old Mar 22, 2004 | 03:51 AM
Midnite 88's Avatar
Midnite 88
Default Re: HELP!!!! This is driving me nuts ... (GhosTRydeR_92)
Have you checked the resistance of your injectors? I seem to remember that they should be either 17 or 19 OHMS.
Have you done a compression check of the 2 suspected cylinders?
What do the plugs look like on the cylinders that you think are missing?
Old Mar 22, 2004 | 04:16 PM
GhosTRydeR_92
Default Re: HELP!!!! This is driving me nuts ... (Midnite 88)
im goin to check the compression right now and the resistance of the injectors. ill let ya know what i come up with thanks for your help midnite ill keep u guys posted. maybe after some good info u guys might have better idea what my prob might be thanks dax :thumbs:
Old Mar 22, 2004 | 05:51 PM
redwing76's Avatar
redwing76
If it was my car I'd replace all the plugs with Autolites and all the wires with Motorcraft wires.
If that didn't do it I'd then turn to the distributor. Cap and rotor.
If I still had a problem I'd pull each plug for a reading.
One other thing run the car at night and look for a spark problem.
Old Mar 22, 2004 | 07:39 PM
GhosTRydeR_92
Default Re: HELP!!!! This is driving me nuts ... (redwing76)
thanks redwing :thumbs:
Old Mar 22, 2004 | 09:04 PM
ductape's Avatar
ductape
Cruise-In V Veteran
:iagree: All good ideas. If you don't find it, post this in the
C4 Tech/Performance section. Those guys laugh at problems like this :yesnod:
Old Mar 22, 2004 | 09:16 PM
GhosTRydeR_92
Default Re: HELP!!!! This is driving me nuts ... (ductape)
one other thing do i check compression while its running or just by cranking it over a couple time ??
To HELP!!!! This is driving me nuts ...
