only the general would think of making one radio into two!!! can someone please explain, why in the world they would take a radio and split it in two? the head, which is the same size as any ford or chrysler complete radio, then put a reciever buried under the glove compartment!!! lunicy!!!! i went to put in my new tunes the other day and imagine my suprise when th connectors didn't fit. upon further investigation i found out about the reciever portion. i got so frustrated i had to walk away, not enough time yesterday. does anyone know if the wires from the reciever (including the anttena wire) will reach the standard location :rant: :rant:
Just for clarification... Bose makes the speakers, Delco makes the hardware components (or OEMs them from audio manufacturers). Kind of why it says Delco-Bose on the front.
You'll need to get an extension for your antenna wire. My secondary box was mounted in the rear. Had to use a 10' extension to get the wire up there. But, my system now sounds better than the stock system ever did! (I didn't have the Bose system, just the base am/fm tape deck)
