84 temp, sender
Old Mar 25, 2004 | 02:10 PM
sindy's Avatar
sindy
Default 84 temp, sender
where can I find the sender to watertemp?,It stays at LOW all the time.somebody that can help??
Old Mar 25, 2004 | 04:20 PM
rick lambert's Avatar
rick lambert
Default Re: 84 temp, sender (sindy)
Not quite sure I understand the question Sindy, but the Temp sender is located on the passenger side of the car back by the dip stick. The coolant level switch is on the passenger side of the radiator-which tells you when your radiator is low on coolant. Hope this helps, and I'd love to make it to Norway :D
[Modified by rick lambert, 9:21 PM 3/25/2004]
Old Mar 25, 2004 | 05:13 PM
vetteboy88's Avatar
vetteboy88
I'm sure it's in the same place as my 1988, passenger side of the block near the oil dipstick, among plug wires. Just a tip, if it is staying at low temp, jiggle the wire connection to the sending unit. A forum member told me this and it worked!!! :steering:
To 84 temp, sender
