Headlight motor restoration?
Old Mar 28, 2004 | 09:43 AM
one-way's Avatar
one-way
Default Headlight motor restoration?
Pulled mtr,This morning.Where should i send it? MAD or Ecklers,Is there others. Who has Had this done? 1987 model.
Old Mar 28, 2004 | 10:56 AM
baddmann's Avatar
baddmann
Default Re: Headlight motor restoration? (one-way)
All you have to do is order some bushings from MAD. They are around $5.00 per motor. If you already have them taken out of the car, the hard part is over.
Search for "headlight motor" or check under tech tips for more detailed info.
:cheers:
Old Mar 28, 2004 | 01:08 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
I have a nice 2 page article on this that I will be glad to send to you. Send me your home address and I will drop it in the mail Monday. corvetteronw@hotmail.com :steering:
Old Mar 28, 2004 | 03:48 PM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
Trust me, you CAN do this yourself! :yesnod:
Old Mar 28, 2004 | 06:04 PM
one-way's Avatar
one-way
Default Re: Headlight motor restoration? (corvetteronw)
I did the gears about 6 mo. ago worked great! now with the test light showing power,motor does nothing.New relay before testing with light,Its spring nights,getting into my drive time!can bushings cause this?should i move this to tech.
Old Mar 29, 2004 | 06:40 PM
brdd's Avatar
brdd
Yep, try it there. You just might get a headlight motor guru..... :yesnod:
To Headlight motor restoration?
