so i should be able to smoke an integra type r, all stock like nothing...what kind of simple newbie mods can i do to the engine? like intake, and headers? which brands are good? or what can i do to do simple mods to it first?
From: "Drive like Hell, you'll get there faster." Tucson AZ
Re: 1/4 for c4? (evilryu530)
When my 90 was stock with over 100k on it...it ran a 13.86. I haven't taken it to the track since then cuz I learned I can't get insurance if I'm within 100 ft of a drag racing track. Now I do all my races illegally on the street because of it.
See my signature below. Both vette were showroom stock right down to the GSC tires.
BTW - Stock to me is the way the car rolled off the assembly line. Some people pull off sway bars put drag shocks, stickier tires etc and still say they ran a certain time in stock condition. That's like false advertising. :lol:
a basically stock 87' auto Z52 W/3.07 gears did a neck snapping.....14.40@96.76mph at 410ft above sea level. it was consistant but had poor timing that killed perfomance.prolly would have done closer to a 14.20@98mph if i knew my initial timing was set a TDC!!! :crazy:
Just ran a 13.3 this past tuesday in my basically stock 95 6spd, and thats with a 2.198 60ft time. Traction was my main issue as I would spin bad on the 1-2 shift, it would kick out a bit in 3rd, and bark in 4th. All I have is a hypertech and mufflers cut off
after getting some advice on here about taking my 95 vert to the track i decided to go and i got a 13.2 with it! it is 100% stock with 3.07's
another c4 vert was there he called my run a "miracle run" but i'm seeing on here for l98 guys are gettin 13.6 stock so i guess it was a good run for my 95 but i wouldn't call it a miracle.
Miracle run ? Point him towards some of Mr Mojo's times.. he's in the high 12's with an (almost) stock '95 :yesnod:
