Advice needed on Opti Spark Mod Kit
Old Mar 29, 2004 | 12:49 AM
jwatty's Avatar
jwatty
Default Advice needed on Opti Spark Mod Kit
Has anyone installed an opti spark mod kit to prevent water damage on the 92s etc?.
Old Mar 29, 2004 | 09:11 AM
C4Crazy787's Avatar
C4Crazy787
Default Re: Advice needed on Opti Spark Mod Kit (jwatty)
I upgraded my Opti-spark as-per the Corvette Fever Tip http://www.corvettefever.com/howto/16758 using the GM vacuum harness # 12558921.
The toughest part was getting the plastic "Y" sealed up to the plastic Opti cap, the 10$ soldering iron I bought got a workout. I wanted to make sure it was sealed, so holding my finger over the end of the "Y" I would fill the cap up with water, finally after about 6 tries I got it to hold water, no drips .
This Opti has about 9k miles on it and the seal was already cracked at the bottom, so I replaced them with (sensor safe) RTV.
Here are a couple of pictures of the finished product. http://www.digitalcorvettes.com/phot...optivent01.JPG
http://www.digitalcorvettes.com/phot...optivent02.JPG
Old Mar 29, 2004 | 10:15 AM
bogus's Avatar
bogus
I never did like the soldering iron idea... I used a carbide bit on a dremel and some heavy duty epoxy. no leaks!
To Advice needed on Opti Spark Mod Kit
