Tachometer Problem
Old Mar 29, 2004 | 02:36 PM
seawolf's Avatar
seawolf
Default Tachometer Problem
My tach has developed a problem and I need some advice please. When driving slowly it works fine. If I get on it it is fine till about 3000RPM's and bounces all over the place and is impossible to read or even guess where it is supposed to be. I searched older archives, but this seems to be different in as much as it works fine if you go slow :confused: Does a 94 have that tach filter? and if so is it correct to cut off or should I look for a new one. The shop manual doesn't seem to address it either. Thanks for any help. :flag
Old Mar 29, 2004 | 03:04 PM
bogus's Avatar
bogus
Default Re: Tachometer Problem (seawolf)
there is a tach filter on the LT1... it's up front near the coil, behind the powersteering pump tank.
Old Mar 29, 2004 | 07:36 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: Tachometer Problem (bogus)
surprise :D :D
To Tachometer Problem
