Front End Squeak
Old Apr 7, 2004 | 07:47 PM
Brtheez's Avatar
Brtheez
Default Front End Squeak
I was wondering if anyone could give a diagnosis. When I go over speed bumps or bumps that make the front end raise I get a squeaking. Is this the shocks or the bushings or something else. Any ideas? :confused: Thanks.
Old Apr 7, 2004 | 08:10 PM
Sandy S's Avatar
Sandy S
Default Re: Front End Squeak (Brtheez)
Could be bushings.
But also try some easy stuff like putting some grease in the guide pins that positon the hood and also on the hood latch mechanism. That helped mine. I also had one worn hood hinge that was causing the front to go up and down.
Have some one stand by the car and listen too.
Old Apr 7, 2004 | 09:21 PM
Steel Blue 91's Avatar
Steel Blue 91
You can narrow the squeak down by using WD-40 or something similar. Spray one of the bushings and go for a ride. If it didn't help, go on to the next. If you have sprayed all of the bushings and still have the squeak, then move on to the shocks, guide pins, hood hinges, etc.
Old Apr 8, 2004 | 03:57 PM
Brtheez's Avatar
Brtheez
Default Re: Front End Squeak (Steel Blue 91)
I believe it has something to do with the suspension, because it only happens when go over large smooth raises or bumps. It reminds me of the shocks compressing and then you hear the squeak. Does that make sense.
Old Apr 8, 2004 | 04:00 PM
vader86's Avatar
vader86
Sway bar bushings, mine does it too
Old Apr 8, 2004 | 04:06 PM
Red90Coupe's Avatar
Red90Coupe
Default Re: Front End Squeak (Sandy S)
:iagree: Thats what my annoying, hard to find squeak turned out to be.
Old Apr 8, 2004 | 04:09 PM
dtorc4's Avatar
dtorc4
Default Re: Front End Squeak (vader86)
:iagree: on both.
Old Apr 8, 2004 | 07:43 PM
84FromHell's Avatar
84FromHell
when mine did that it was the rubber blocks attached to the spring. :cry
Old Apr 8, 2004 | 10:07 PM
Metamando's Avatar
Metamando
Default Re: Front End Squeak (84FromHell)
Mine only does it when cold, but its the bushings. As soon as mine totally fall out, Im going for poly.
:seeya
Old Apr 8, 2004 | 10:12 PM
Southern Comfort's Avatar
Southern Comfort
Mine does it too. But, only when the car is cold. Like maybe before the shock's pistons and oil heats up. I vote shocks :yesnod:
Old Apr 9, 2004 | 03:27 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Have to go with the bushing side...
Old Apr 9, 2004 | 08:53 PM
Brtheez's Avatar
Brtheez
Default Re: Front End Squeak (vinnies87)
If I decide to oil the bushings, should I us a silicone spray? :confused:
Old Apr 10, 2004 | 05:15 AM
MaSTeRofDZaSTeR's Avatar
MaSTeRofDZaSTeR
From: "Drive like Hell, you'll get there faster." Tucson AZ
It's probably the shocks if it's coming from under the wheel bay, but if it sounds closer to the cockpit, it could definitely be something as simple as the hood latch or even your door hinge frames on speed bumps. I sprayed mine down with WD-40 aswell as the hood latches and haven't had any yet. Also, if you're braking on the speed bumps, it could come from your brake shoes when the calipers hit em. Spray em down with some Stop Squeak if that's the case. They make many of those products that you can just spray on without having to take apart the wheel bearings, etc. I had all of these probs cept for my shocks, cuz I didn't replace them and I haven't had a squeak since over a speedbump now.
Old Apr 10, 2004 | 10:15 AM
vetteboy88's Avatar
vetteboy88
same problem on mine....It's the bushings........when there done, get the poly....for now, put some silicone on it...... :smash:
To Front End Squeak
