VBP rear spring
Old Apr 9, 2004 | 09:13 AM
dieseltech's Avatar
dieseltech
Default VBP rear spring
Has anyone had any experience with the VBP sport rear spring??
Old Apr 9, 2004 | 03:01 PM
atotalnincompoop's Avatar
atotalnincompoop
Default Re: VBP rear spring (dieseltech)
search the archives for VBP, there are a lot of threads there regarding it. :yesnod:
Old Apr 10, 2004 | 10:19 AM
dieseltech's Avatar
dieseltech
Default Re: VBP rear spring (atotalnincompoop)
Thanks for the help. I was hoping to find someone who had installed one on a C4. They say to not use any spring spacers with it. Also they suggest using different bolts so you can adjust the ride height. I am wondering if the spring will change the height much???
Old Apr 10, 2004 | 08:09 PM
neverendingproject's Avatar
neverendingproject
i have it. you do need to follow their advice. the rubber at the mount is thick enough that spacers aren't necessary. it will raise the rear of your car a bit. longer bolts will let you lower it some.
Old Apr 10, 2004 | 08:59 PM
okinawa86vette's Avatar
okinawa86vette
Default Re: VBP rear spring (neverendingproject)
I've had a vb sport rear spring(same one) on both my '86 and 88. I believe my 86 had different end bolts, cause it sat quite a bit lower. My '88 didn't sit noticably higher when I bolted the spring up, but did after I installed a full set of poly bushings, so maybe my old bushings were causing some sag.
Do follow their instructions and install it w/o the spacers.
Chris
Old Apr 10, 2004 | 09:55 PM
dieseltech's Avatar
dieseltech
Default Re: VBP rear spring (okinawa86vette)
thanks guys, much appreciated
To VBP rear spring
