Problem nearly solved...
Old Apr 9, 2004 | 12:29 PM
RED-85-Z51's Avatar
RED-85-Z51
Default Problem nearly solved...
Well, On advice from the forum, i went out to check timing on the hard starting 85.
I unhooked the Tan Wire fro mthe Distributer, hook up the light, and cranked it over...it cranked immediatly, no smoke, no problems! I checke to see what this wire does in my haynes book.
It says that this wire goes to the Ignition Module Bypass output on the ECM.
What does that mean?/??/??
To check, I rehooked the wire, cranked it, and it turned over for 4 seconds before catching ,it did its usual smoke job, and fumbled.
Old Apr 10, 2004 | 04:10 AM
Q1KSLVR's Avatar
Q1KSLVR
Default Re: Problem nearly solved... (RED-85-Z51)
It takes away any advance added by the ECM, giving you "base timing".
Once you pull that wire, you set the timing, and then reattach. :thumbs:
Old Apr 10, 2004 | 05:36 AM
ductape's Avatar
ductape
Cruise-In V Veteran
hmmm...That's wierd :skep: you might have a module or computer prob
To Problem nearly solved...
