Getting a code 36 "Help"
Old Apr 12, 2004 | 07:41 PM
dzierke's Avatar
dzierke
Default Getting a code 36 "Help"
Here's a new code I've never seen before.
Brief history on repairs: I've replaced my MAF in the past after getting a code 34. It corrected my idle surges 2 years ago.
Today I go start up the beast and it's hard to keep idling plus the check engine lite is on. Smells like it's running rich. I limp it home, check for codes and come up with 36. My shop manual says to check power relay & burn off relay. Unfortunately there isn't info on where these relays are located on my 86. Also I am looking for my fuel pump relay.
Anyone know where these relays are hiding under my nose? I stopped by a local auto parts store to get the relays so I would at least know what they look like. The zit faced kid working the counter didn't have a clue what I was talking about. About as helpful as my golden retriever.
Are these relays dealer only parts?
Any advice would be much appreciated...
Old Apr 13, 2004 | 03:26 AM
dzierke's Avatar
dzierke
Default Re: Getting a code 36 "Help" (dzierke)
Not one response? :beatdeadhorse:
Old Apr 13, 2004 | 04:08 AM
Midnite 88's Avatar
Midnite 88
Check the firewall behind the battery for the MAF and Burn-off relay's. Not sure about the fuel pump relay.
Mike.
To Getting a code 36 "Help"
