Testing a MAF sensor??
Old Apr 13, 2004 | 09:11 PM
dzierke's Avatar
dzierke
Default Testing a MAF sensor??
Been trying to fix a problem that started yesterday. Rough idle, wants to stall and smells like it's running rich. Also had a code 36 regarding 2 MAF relays. Changed the relays, installed new plugs, cap and rotor. Started it up and no change. Still runs like crap! I also had the ignition module tested and it checked out fine. How do I test my MAF other then a burn off check to see if it's working properly? BTW, fuel pressure holds at 50 psi when running. Any other ideas on what else to look at? :beatdeadhorse:
Old Apr 13, 2004 | 09:15 PM
bogus's Avatar
bogus
Default Re: Testing a MAF sensor?? (dzierke)
I just replaced one on bastet44's 87...
According to Gordon Killebrew, the earlier vintage MAFs are problematic.
Sadly, I don't have a book here to help you diagnose the unit...
Old Apr 13, 2004 | 09:34 PM
dtorc4's Avatar
dtorc4
With the car running, take a screwdriver and tap the housing. If the car seems to miss more while you're tapping it, then your MAF is toast.
Old Apr 13, 2004 | 09:39 PM
VettBrat's Avatar
VettBrat
My mechanic told me to unplug the MAF. If it ran better the MAF was bad.
Old Apr 13, 2004 | 09:41 PM
dzierke's Avatar
dzierke
Default Re: Testing a MAF sensor?? (dtorc4)
:beatdeadhorse: :beatdeadhorse: :beatdeadhorse:
I did understand how tapping my MAF will make my car run worse then it already does.
Anyone have a better idea?
Old Apr 13, 2004 | 09:44 PM
dzierke's Avatar
dzierke
Default Re: Testing a MAF sensor?? (VettBrat)
Will try that and let you know what happens...
Old Apr 13, 2004 | 11:28 PM
JCAIRE2's Avatar
JCAIRE2
50lbs. is a little high, might explain the rich condition. Only other way I can think of to test the MAF is to hook up a scanner and look at the gm/sec the MAF is telling the computer.
Old Apr 15, 2004 | 08:08 PM
dzierke's Avatar
dzierke
Unplugged the MAF as suggested and my idle cleared up. Went down to a local parts place and picked up a rebuilt MAF for $150 w/ a 1year warranty.
My car is back to it's normal self again.
Thanks guys!
BTW: The parts guy did mention the sometimes you can get it to act up by tapping :smash: on it if it's an intermittent problem...
:thumbs: :thumbs: :thumbs: :thumbs:
To Testing a MAF sensor??
