service engine light on
Old Apr 14, 2004 | 11:30 AM
baerguy's Avatar
baerguy
Cruising
Default service engine light on
just got done with a several week odyssey of plug change, ignition wires, knock sensors and cooling system flush. I had the battery disconnected a bunch of times. Everything is done (correctly I think) but I have a service engine light on. Does one of the computer mods have to reset themselves or should I be nervous. Car seems to run fine the one time I drove it. There are no codes flahing on the dash panel.
Old Apr 14, 2004 | 12:16 PM
Aaron71771's Avatar
Aaron71771
Default Re: service engine light on (baerguy)
Double check your electrical and vacumm lines.
Old Apr 14, 2004 | 12:26 PM
Moxxi's Avatar
Moxxi
Check your codes with a jumper wire, with the key turned on, but NOT STARTED. This will tell you if you have a problem.
To service engine light on
