Apparently need a new one of these in addition to the shocks, too. What's the deal here? I'm not thinking of doing this myself, but I'm curious to see if this is a "gotta go to the dealer" type of repair, or if I can just buy the belt and take it to any ol' shop and have them put it on.
That may be the eaisest repair on a Corvette. Five minutes. Prices vary. A Gates Gatorback will run in the $30.00 range. A Dayco about a ten spot less. Have no idea what the Chebby Sto would rip you for. I am running a Dayco but am about to change to a Gatorback.
:iagree:
The belt routing should be on a decal on the radiator. You just use a 1/2
drive breaker bar in the belt tensioner located under the air compressor in the front to loosen the belt and replace it.
:thumbs:
Thats what I bought the belt tool, $40.00 came with 3 sockets and 3 crows feet, and a long bar and a short bar.
I 've used it on 2 cars now. Its a snap with the tool.
Yeah, the tool makes it much easier on the LT1/4. A regular ratchet will hit the crossmember. Darn GM.
:iagree: I have taken my belt of twice in the last week. Once to get rid of the frisbee and the second time to get rid of the air pump. Both times I used a regular breaker bar. It is a bit trickey positioning it for the first time but is simple enough that I would never pay anyone to do it for me. Plus the sticker showing how to put it back on helps too. If you have never done it before, I would set aside 9 minutes and 45 seconds to do it.
3 minutes to figure out how to get the breaker bar into the tensioner
30 seconds to remove the current belt.
5 minutes to place the new belt on and make sure you have it wrapped around all of the pulleys correctly
1 minute to double check your work and remove the breaker from the tensioner.
15 seconds to grab a beer and celebrate a job well done
:cheers:
:cheers:
