What Fuel Octane ????
Old Apr 18, 2004 | 06:38 AM
zog's Avatar
zog
Default What Fuel Octane ????
I have an 86 L-98 Vette. I have had the car for over a year and always put premium (93 octane) in the car...
I finally read the owner's manual (surprise!!) and it says the car should have 87 octane...regular unlead gasoline!?!?!?!?!
My understanding is that too high an octane is not only a waste of money, but can cause carbon buildup in the cylinders and a host of other problems...
So, I started to run a few tanks of mid-grade (89 octane)...I some how can't bring myself to run regular gas in a Vette.
One thing I did notice is that the perpetual SES code 32 (EGR) quit coming on when I drove the car...could the improper octane really cause this problem??
What octane do other early C4 owners use and recommend??? thanks :cheers:
Old Apr 18, 2004 | 06:40 AM
Alchemist's Avatar
Alchemist
NC Events Coordinator
Default Re: What Fuel Octane ???? (zog)
IMHO...i'd run whatever octane i know the Vette performs well with. If it's 93...fine. If there's not a noticeable difference in performance with 87, why spend the extra $3-4 at each fill-up for premium?
Old Apr 18, 2004 | 07:10 AM
LoneStarSoldier's Avatar
LoneStarSoldier
Default Re: What Fuel Octane ???? (Alchemist)
I have used nothing but regular unleaded (87) and no trouble at all. You people who use the higher octane, these rich oil companies LOVE you. Cost you at least 20 cents a gallon more, costs the oil companies about 2 cents a gallon more to make it.
HAVE A GREAT DAY!!! SPEND THAT MONEY!!!!!!!!!!!
:flag :flag
Old Apr 18, 2004 | 08:13 AM
Nathan Plemons's Avatar
Nathan Plemons
Woohoo! I get to be the first guy to use this guy on a thread :beatdeadhorse: :beatdeadhorse:
The short of it is that you want to use the LOWEST octane fuel that your car will burn while still maintaining full spark advance. Meaning that if your car pings on 87 and has to retard the timing it will run just fine but you're giving up performance. Meanwhile if it can run full spark advance on 87 without detonating you are simply throwing your money away by going with anything higher.
:cheers:
Save your money and put in the cheap stuff
Old Apr 18, 2004 | 11:46 AM
vetteboy88's Avatar
vetteboy88
HHHMMMMMMMm always used 93 without giving it a second thought. I guess I have been feeding the gas company's :U :U
Old Apr 18, 2004 | 11:56 AM
vader86's Avatar
vader86
The highest grade I use is the 89, usually 87 though, the 86 with Iron heads doesnt need the octane. The compression ratio is too low.
Code 32 doesnt come from that. Its a EGR switch/solenoid failure. Extended part-throttle running on the hwy at over 170F will open the EGR. Your pipe could also be plugged, or you just need to tighten your gas cap (vacuum loss)
Old Apr 18, 2004 | 11:58 AM
redwing76's Avatar
redwing76
Default Re: What Fuel Octane ???? (vetteboy88)
Some cars require 93. A L-98 runs fine on mid grade, but 87 will choke a lawn mower. If the tank opening says 93 then 93 it is.
My Mercedes says 93 and thats a $10,000 motor so I use 93 in it.
Old Apr 18, 2004 | 11:59 AM
JB666's Avatar
JB666
Default Re: What Fuel Octane ???? (Nathan Plemons)
:cheers:
Your serious, the LT1 will run, with no problems, on -92 octane gas?????? I'm serious, I've NEVER put anything under 92-93 in, and with prices the way they are, it's been killing me!!!!! This would come as a relief!!
Old Apr 18, 2004 | 01:26 PM
xlr8nflorida's Avatar
xlr8nflorida
Default Re: What Fuel Octane ???? (JB666)
Yes the opti will adjust the timing so you don't get detonation.
I wouldn't do it - the LT1's specifically call for premium.
Old Apr 18, 2004 | 01:37 PM
Nathan Plemons
It will run with no problems on lower octane fuel, HOWEVER you'll probably be giving up some power. The LT1 makes 10.5:1 compression from the factory and specifically calls for premium. To know for sure you would really need to data log the car and see if you are getting any detonation and spark retard on lower octane fuels. The reverse flow cooling does help the LT1 in running the higher compression ratio.
On the older TPI cars with lower compression there is no need for the higher octane fuels.
Old Apr 18, 2004 | 01:48 PM
dieseltech's Avatar
dieseltech
GM recommends using high detergent fuel. Premuim grade generally contain higher detergent levels than regular.
Old Apr 18, 2004 | 02:15 PM
LoneStarSoldier
Default Re: What Fuel Octane ???? (dieseltech)
Forget the so called detergents most of them were taken out years ago because of pollution issues. Check your owners manual and go by it. Most of you driving early C-4's can use regular and a bunch of you with later C-4's can too. Don't let this big mystique of " I've Got a Wonderful Corvette" get between you and the big bucks you are paying for gas that you don't need and it's probably doing more harm than good.
HAVE A GREAT DAY!!!
:flag :flag
Old Apr 18, 2004 | 02:19 PM
JB666's Avatar
JB666
:cheers: Ok, thanks - I was wondering about that!! I've heard a lot of people post the exact same thing you just said, about the LT1...
Old Apr 19, 2004 | 02:03 PM
SteveBlack90's Avatar
SteveBlack90
Default Re: What Fuel Octane ???? (redwing76)
My tank opening says "Premium Recommended", so that's what I have been using (93 octane in Illinois). I haven't considered using a lower grade. My L98 has 9.5:1 compression; maybel I could use 89, but I haven't tried it.
Old Apr 19, 2004 | 03:22 PM
89Corvette6spdFX3's Avatar
89Corvette6spdFX3
I'll try both and see what works!
Old Apr 19, 2004 | 03:47 PM
Vetterin's Avatar
Vetterin
Default Re: What Fuel Octane ???? (89Corvette6spdFX3)
I not only run 87 but I buy the CHEAPEST gas I can find since Joe Blows' gas Shell, Mobile and everyone else's will usually be formulated AND delivered in the SAME tanker trucks from the same refinery. The extra additives that are said to be in the "better" gases are a myth. "Believe it or don't."
Old Apr 19, 2004 | 04:12 PM
jay17's Avatar
jay17
I've always used 89 with no problems.
To What Fuel Octane ????
Old Apr 19, 2004 | 06:27 PM
xlr8nflorida
Default Re: What Fuel Octane ???? (Vetterin)
You can buy cheap condoms to but I wouldn't recommend it. :lol:
Yes most gas comes in the same tankers but each company has their own set of detergents and most studies show its good to change from gas station to gas station every few months. AMMACO & BP are my favorite.
Almost all the brands are good, Shell, BP, AMMACO, HESS the list goes on and on but to buy Gas from Cheap places like the starvin Marvin down the road with the mystery no name gas---- no thanks. I have seen too many problems with bad tanks and or water in them.
Old Apr 20, 2004 | 01:12 AM
dieseltech's Avatar
dieseltech
Default Re: What Fuel Octane ???? (xlr8nflorida)
Tanker trucks have several different compartments in them with different grades of fuel.
Old Apr 20, 2004 | 02:16 PM
JasonL's Avatar
JasonL
91 octane in my LT4, which is what the owner's manual recommends. No knock retard...
