90 corvette starter problem
Old Apr 28, 2004 | 07:06 PM
90corvette's Avatar
90corvette
Default 90 corvette starter problem
when i turn the key the engine turns just a little. battery is full charged . sounds like the starter ????? is it hard to change any pointers, thanks for the help
Old Apr 28, 2004 | 07:18 PM
Wheelman's Avatar
Wheelman
Default Re: 90 corvette starter problem (90corvette)
Does the engine actually crank, or are you just getting a "click" from the starter?
Old Apr 28, 2004 | 07:41 PM
90corvette's Avatar
90corvette
Default Re: 90 corvette starter problem (Wheelman)
it turns about 1/8 inch
Old Apr 28, 2004 | 08:02 PM
Pete K's Avatar
Pete K
I would clean and check cable connections on both ends. I would then have battery load tested. Discount auto stores usually do this quicly and for free. If this checks good, probably starter.
To 90 corvette starter problem
