Could someone post a link to instructions on how to replace an Oxygen Sensor on my '91 and let me know if it is too complicated to undertake. :flag
:cheers: Generally one of the easiest replacements. O2 sensor is located in exhaust pipe, just below the flange with the exhaust manifold.
There is a special socket recommended to allow socket to go over the wire from the sensor. Cost of the socket is a lot less than the cost of a service tech doing the job
Simply unscrew, and screw in the new one....BE SURE TO HEED THE DIRECTIONS on installation with antiseize!
