Window will not go down, Need help
Old May 4, 2004 | 08:58 AM
84 Cherry's Avatar
84 Cherry
Default Window will not go down, Need help
I have an 84 and the passenger window will not go up or down. It is open about 2/3 of the way. So I took the panel off and after reading the manual I can't get the regulator out because the window is down to far to line the holes up. Is there any manual way to open/close the window? Any help or ideas would be greatly appreciated.
Thanks,
Solomon
Old May 4, 2004 | 09:48 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Default Re: Window will not go down, Need help (84 Cherry)
If it is the window ribbon it is most likely trash and will need to be replaced, just try to break the ribbon and remove the parts you may be able to move the window up and down by hand.
Old May 5, 2004 | 08:10 AM
84 Cherry's Avatar
84 Cherry
Default Re: Window will not go down, Need help (We Gone)
Is there any way other than breaking the ribbon to open it manually? Like a gear or bolt that will open it up?
Old May 5, 2004 | 08:20 AM
FASTAZU's Avatar
FASTAZU
St. Jude Donor '16
If you can reach the nuts that hold the glass to the regulator assembly you should be able to remove the glass
Old May 6, 2004 | 10:54 AM
redwing76's Avatar
redwing76
:iagree: Thats the way I do it.
Check for a fuse, power to the switch, power to the motor.
Old May 6, 2004 | 02:15 PM
stalkervette's Avatar
stalkervette
Default Re: Window will not go down, Need help (redwing76)
You can also have someone press the window up button while you pull the window up with your hands. After that find a regulator for a later model and take the door panel off and remove the whole regulator assembly and replace it with the newer style. :hurray:
To Window will not go down, Need help
